How do you manage details when 2 roofs connects. using cut profile really sucks, especially when I cant hide their lines. Draw on top of them white line would spoil hatch pattern. Drawing on top filled regions would take plenty of time. Suggestions?
Detailed callout - Roof connection workaround
I am having issues creating this roof. I am currently using three different roofs, one for the front gable, one for the long gable, and one for the flat...January 27, 2011, 08:48 PM
Hi, i need help urgently with this roof profile. I need to create a roof that sweeps upwards, and is in a curve roof profile. Is there a way i can do...December 30, 2011, 12:37 PM
I am having trouble with merging the porch roof with the main bulding roof. I've attached the file an a screen shot. Any ideas?...August 24, 2018, 08:09 PM
Is there a way to set a gable roof peak that isn't centered on the roof, while keeping the same slope on both sides? The only work around I was able to...April 25, 2018, 05:56 PM
I've got an issue on a job where the two roofs refuse to join. The main roof was modified and after the change the dormer roof will not join. The only...March 20, 2013, 02:52 PM
