"No Level" objects from Revit?
    RAC 2011.
    NW Export Utility for Revit 2011
    NW Manage 2012
    When exporting .nwc files using the Revit 2011 NW Export Utility plug-in, once the NW file is opened in NW Manage, it has a Category called "No Level"
    and throws all those objects ( for instance door families ) into a horizontal position as if they are lying on the ground plane.
    Has anyone seen this phenomenon and /or know what causes it and how to fix it?
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
