I am currently doing a preservation project for school and was curious the easiest way to reproduce this pic into revit 2012. any help would be appreciated.
I'm not sure the Conceptual Massing tools are necessarily the only choice.........
You could create Masses for this, but then when it's time for documentation
you may not have much "Revit" content to use--unless you convert faces of the Masses to walls, etc.
So--perhaps try using more "normal" Revit tools.......
I'd start with a Family, sweeps, voids, extrusions, etc.
Very challenging modeling exercise indeed. Good luck!
Cliff B. Collins
Registered Architect
Autodesk Expert Elite
Not impossible to create with the Revit tools like Cliff said, but indeed a challenge!
If you only need it for graphical presentation, maybe you could get something out of the photo with Project Photofly? I believe it will create AutoCAD and/or Inventor files which you could import to Revit... Not optimal, but maybe easier and faster than modeling it in Revit. At the end of the day, it depends on what you expect from the finished product within Revit.
Scott
it can be done but, u will need time to get it done. There is another way to do it. AutoCAD or 3D MAX, but than this object will not be parametric, so you will not be able to add or change something. If I were you, I would do it in Revit in spite of taking of time.
If a builder builds a house for someone, and does not construct it properly, and the house which he built falls in and kills its owner, then the builder shall be put to death. (R) Code of Hammurabi
I have gotten:
AutoCAD 2012
Revit Architecture 2011
ArchiCAD 12
Google sketchup 8 Pro
Rhino 4.0
Artlantis 3.0
Adobe Master collection
Does anyone have or know where I can get a family (or mass) of a Oval Dome. I have a project that they want a 20'X40' oval Skylight dome. With a 3'-0"...
I'm currently trying to model an existing building which adjacent to our project building and I'm able to model most of it using walls however there is...
Hi, I'm an architecture student in Spain and im having some difficulties in creating my ideas, heres the sketch of what id like to to and i would like...
Hello all. New to the forum and to Revit. I've been experiencing some odd behavior in Revit and I don't know if it is me (likely) or the software (more...
