Simple exercise, weird reults
    I'm doing a simple exercise with the rhomboid pattern and I'm getting an odd behavior.
    The pattern is set to 2m x 5m and the divided surface to 6m x 20m.
    Any reason why i"m getting those extra parts?
    Here's a link to the exercise in case you want to have a look https://www.dropbox.com/s/nruxrd7xg5...mboid.rfa?dl=0
    Thanks for any help
    I don't have an answer for you, but I can confirm your observation, and second your question. Whenever the Border Tile is set to "Partial", it doesn't cut exactly at the end of the divided surface. It always leaves little slivers of "Overhang". I have encountered this behavior many time, and haven't figured out a fix or a workaround. If anybody here on the forum can help, it will be much appreciated.
      Could be Revit's low geometrical accuracy showing up. See other edges have a corresponding cutout pieces.
