Good Morning,
The dilemma: I know little to nothing about electrical work. I haven't even ventured into that wading pool in Revit.
I was told the electrical person at our office can get along fine in Revit. We use a library supplied to us by an add-on in Revit and I fear the electrical person has done nothing more than pasting relevant symbols into Revit.:crazy:
I see many impressive looking symbols all over the place in the model and it all looks pretty enough but my first clue is the connectors associated with these symbols. None of them are connected if I run the Show Disconnects in Revit.
I stumbled on this problem when someone he was training came and asked me how to show a wiring run in the Revit model. An item connected to a local DB and all the local DB's (about 5 of them) wired to a central box in the passage?
I may be oversimplifying the request somewhat.
He wanted to know how to draw the lines in Revit and in my experience one does not simply draw lines in Revit.
Is this visually possible in the Electrical discipline in Revit?
I know what I can expect to see in Mechanical and Sanitary disciplines as well as the information that can be obtained, but what should I expect to see in Electrical? How much wiring detail should there be?
I'd be most appreciative of some screenshots and if you have time, a little explanation.
In short: Looks pretty, does nothing and has no value, should have been done in AutoCAD.
Ciao for now.
Ciao for now.
