I have set a simple model of 4 steel post steel beams and a floor with a structural deck.
When I try to run the Floor Vibration Analyser extension I get a warning message saying "Ensure selection includes at least one composite slab". What am i missing?
Also when I try to run the Load Takedown Extension I get prompted for "Adoption of Active Section Database" which list my steel section used in the model. I tried to add members to the active database but nothing seem to happen. I have our steel members which are similar to the OOTB members. Are there any criteria or parameter that the steel members have to fulfil to be bale to work?
I have made the material a type parameter rather than an instance for all our members am not sure how that affects it all.
If anyone have any suggestion or input that would be appreciated.
Thanks
J
Thanks
J
