Setting Fresh Air Temperature
    Dear All,
    i have a mechanical system which described bellow:
    Fresh air comes from HRV (Heat Recovery Unit) unit.
    Heating Cooling is done by Fan Coil unit.
    Question is when i set fresh air rate for any zone it calculates heat gain from fresh air based on outside air and indoor air temperature (As fan Supply). However i am using Heat Recovery Unit and want program to calculate with Not Outdoor air temperate but the temperature i specify manually. How it is possible to specify it?
    Thanks in advance.
