When you select the dim tool, you'll see you can default to either wall faces, faces of core(typically what I dim to) or centerlines. Use the tab key to select anything not default.
Scott D. Brown, AIA | Senior Project Manager |Beck Group
"When you select the dim tool, you'll see in the Options Bar...."
I have expanded on Scott B's answer a bit. The Options Bar is the bar that exists between the drawing area and the ribbons. It's context sensitive and changes depending on the tool selected.
Again, following the tutorial, and I’m selecting the split face tool, hovering over the inside corner of a wall, and a tooltip is supposed to verify...
When I am placing the walls and type in a dimension, I want the wall to be placed relative to the inside face of the wall to the inside face of the other...
Relative Noob here attempting to push through the Revit barrier from an AutoCAD starting point. I'm pretty much getting the hang of things and liking...
