I am in the process of upgrading around 12 models all linked with shared coordinates. Am I correct to assume that the shared coordinates file must be updated as well?
Project Upgrade - Shared Coordinates
There is no shared coordinates *file*, only whatever file was used to either Acquire Coordinates or determine what coordinates should be entered into Specify Coordinates at Point. Once set Shared Coordinates are *fixed*, or unchanging.
If a separate file (Revit) was created to deal with a survey and acquire coordinates then, yes, it ought to be upgraded too, so it can be used with the other files if necessary.Last edited by Steve_Stafford; February 6, 2015, 07:59 PM.
Hi all, I am seriously struggling with shared coordinates.
I am trying to set up a model to send to consultants which they can acquire the coordinates...October 25, 2019, 09:39 AM -
There isn't an easy button to just eliminate shared coordinates in a project. You can move the Survey Point back to the same spot as the Project Base...
Channel: Blog Feeds
April 20, 2012, 03:15 PM -
Yes the old Shared Coordinates question again.
I have just published shared coords to a model I have. To check it I unlinked the model...November 19, 2015, 09:31 AM -
Revit's shared coordinate features routinely confuse people. I believe I understand them well but I find the various ways people manage to use them can...
Channel: Blog Feeds
December 16, 2013, 10:15 PM -
We just inherited a bunch of files from another firm and we'd like to keep using the Shared Coordinates.
I know the main rule with SCs is "One...May 26, 2015, 06:58 PM
Monumetric Footer In-screen
