Replace Title Block
    Replace Title Block
    I need to save my file as a new central and replace the title block with a new one.
    how can i do this so that all sheets' title block will be replaced all at once instead of opening them one by one and changing the title block from the Properties?
    Find the titleblock in the project browser, right click, reload family and load in new titleblock. All instances of that titleblock will be replaced. You might also try to select the titleblock, right click, select all instances in project, then change it that way.
      thanks that helped a lot!
