not all fields available in filter in schedules
    When you create a Column Schedule (in RST) and add for example Family name to “Scheduled fields” it is not available to use under the filter tab? What is controlling which fields are available to use for filtering your schedules?
    Thanks,
    J
    That is an OOTB setting for Family Name and I believe that Type Name is the same way. Just something Autodesk won't allow to be filtered on for some reason.
      Yeah it is a bit strange as Family name is available in Filters - isn't that a bit inconsistent
      J
