Adding a family parameter via the api
    Is it possible to add an Instance Parameter to a family in a project via the api if that Instance Parameter does not exist?
    CG Visions
    Revit Coding Blog
    Should be possible. The basic steps would be:
    Iterate over the elements of type Family until you find the one with the desired Name
    familyDoc = projectDoc.EditFamily(theFamily);
    begin a transaction on familyDoc
    BuiltInParameterGroup addToGroup == BuiltInParameterGroup.INVALID; // INVALID= "Other" group, or pick your fave from the enum
    ParameterType parameterType = ParameterType.Text; // Or pick your fave from the enum
    familyDoc.FamilyManager.AddParameter("My Parameter Name", addToGroup, parameterType, true); // true = instance parameter
    close the transaction on the familyDoc
    projectDoc.LoadFamily(familyDoc);
    familyDoc.Close(false)
    To avoid the annoying Overwrite dialog on reload, you can create a class that implements IFamilyLoadOptions and pass it as an additional argument to the projectDoc.LoadFamily call.
      Great- thank you very much!
      CG Visions
      Revit Coding Blog
        Hi DavidVS,
        I was looking at your post and it's amazingly helpful, although I'm getting an error when I try to load the family back into the document. The line that is causing the error is:
        P_doc.LoadFamily(familyDoc, iFamOptions)
        P_doc is a valid document I'm working on
        familyDoc is the family that I am editing
        iFamOptions is a class where I'm implementing the IFamilyLoadOptions
        The exception is: InvalidOperationException that says "This method can only be used with family documents"
        I'm using Revit 2014. Would you have any insight as to how I may be able to solve this problem. Any help is greatly appreciated.
        Cheers,
        [C]
          should reverse it? familyDoc.LoadFamily(P_doc, iFamOptions) instead of P_doc.LoadFamily(familyDoc, iFamOptions)
            I have some code that makes adding shared parameters to a project easy. It could be editted to add Family parameters:
            Code:
            private static bool createSharedParameterFile(Document doc, string paramFileDir, string paramFileName)
                        string paramFile  = paramFileDir + paramFileName;
                        if (File.Exists(paramFile)) {
                            doc.Application.SharedParametersFilename = paramFile;
                            return true;
                        if (!Directory.Exists(paramFileDir))
                            Directory.CreateDirectory(paramFileDir);
                        FileStream fs = File.Create(paramFile);
                        fs.Close();
                        return true;
                    public static bool containsDefinition(DefinitionGroup grp, string paramName)
                        paramName = paramName.ToLower();
                        foreach (Definition def in grp.Definitions)
                            if (string.Equals(def.Name.ToLower(), paramName))
                                return true;
                        return false;
                    public static bool addSharedParameter(Document doc, BuiltInCategory paramCategory, string paramName, ParameterType paramType, string definitionGroup="APIGroup", bool isParamVisible = true)
                        try
                            if (!createSharedParameterFile(doc, "PARAM_FILE_DIR", "PARAM_FILE_NAME"))
                                return false;
                            DefinitionFile parafile = doc.Application.OpenSharedParameterFile();
                            CategorySet categories  = doc.Application.Create.NewCategorySet();
                            categories.Insert(doc.Settings.Categories.get_Item(paramCategory)); // pipeSymbol.category
                            InstanceBinding binding  = doc.Application.Create.NewInstanceBinding( categories );
                            DefinitionGroup apiGroup = parafile.Groups.get_Item(definitionGroup);
                            if (apiGroup == null)
                                apiGroup = parafile.Groups.Create(definitionGroup);
                            // Check that param is not already in file
                            if (containsDefinition(apiGroup, paramName))
                                return true;
                            BindingMap bindingMap = doc.ParameterBindings;
                            Definition visibleParamDef = apiGroup.Definitions.Create(paramName, paramType, isParamVisible);
                            bindingMap.Insert(visibleParamDef, binding);
                            return true;
                        catch (Exception e)
                            /*var st = new StackTrace(e, true);
                            var frame = st.GetFrame(0);
                            var line = frame.GetFileLineNumber();
                            TaskDialog.Show("","Line: " + line.ToString() + ", Error: " + e.Message);*/
                            return false;
                    public static bool setupSharedParameters(Document doc)
                        try
                            addSharedParameter(doc, BuiltInCategory.OST_IOSModelGroups, "Name", ParameterType.Text);
                            addSharedParameter(doc, BuiltInCategory.OST_IOSModelGroups, "Type", ParameterType.Text);
                            addSharedParameter(doc, BuiltInCategory.OST_IOSModelGroups, "Style", ParameterType.Text);
                            addSharedParameter(doc, BuiltInCategory.OST_IOSModelGroups, "Breakline", ParameterType.Text);
                            addSharedParameter(doc, BuiltInCategory.OST_IOSModelGroups, "Colour", ParameterType.Text);
                            addSharedParameter(doc, BuiltInCategory.OST_IOSModelGroups, "Chainage", ParameterType.Number);
                            addSharedParameter(doc, BuiltInCategory.OST_IOSModelGroups, "Weight", ParameterType.Integer);*/
                            return true;
                        catch (Exception e)
                            TaskDialog.Show("","Error: " + e.Message);
                            return false;
              Thanks for the notes. Much appreciated!
              Cheers,
              Code:
                              return true;
                          fs.Close();
                          return true;
                                  return true;
                          return false;
                          try
                                  return false;
                                  return true;
                              return true;
                          catch (Exception e)
                              return false;
                          try
                              return true;
                          catch (Exception e)
                              return false;
