Emergency lighting
    Emergency lighting
    Using rvt 14'
    I cannot for the life of me find a emergency lighting family that is not wall hosted pre 11' or what ever is it (no longer oriented correctly when upgraded to 14') OR i get a IES file Parse error no matter what IES file i seem to put in the family
    using elumtools
    does anyone have a family that works that i can use?
    spec'ing something similar to this:ELT - Titan® Die-formed Steel Emergency Unit
    William Fletcher
    IPD Engineering
    Linkedin
    So just to be clear - you need a face based emergency light that was made in a Revit 2011 release or earlier?
    The true sign of intelligence is not knowledge but imagination.
      that same family keeps popping up everywhere
      it is not oriented correctly
      it comes in as the instance on the left, i rotated but it still is hosted from the bottom of the fixture
      William Fletcher
      IPD Engineering
      Linkedin
        Try this.
        It may take some additional massaging to get it just right.
          Try this.
          I'm in 14', can't open
          William Fletcher
          IPD Engineering
          Linkedin
            Whoops - try this one.
              Did this end up working for you WG?
                ya sorry i didnt get back to ya
                still having trouble with IES files which is kind of the real issue
                not sure if its me or the ies files that are being provided??
                William Fletcher
                IPD Engineering
                Linkedin
                  I've had some issue with IES files showing inaccurate(low) lighting levels in Revit even when the same IES is used successfully in another program(elumtools, visual, etc..), but it sounds like you're having a different issue.
                  Hope someone can elaborate on the 'parse error'.
                  Any chance you could post the exact error message you're receiving?
                    I know I am 4 years late but i have made some slight change to the family. It should now be a wall-mount, parametric and aethestically closer to the original family.
                    Hope it helps somehow or for whoever is searching for an emergency light in the future.
