disconnect top and bottom of a wall
  • mdradvies
    Originally posted by François View Post
    Ok, but is there a general tool which enable us to detach all the walls without selecting one (or more)? I imagine a tool 'Detach all the walls'. It may doesn't exist, I just ask.
    Nope, it's not there. I suppose it can be mounted using API, since it's just a series of commands. But I wouldn't use it. In my opinion, detaching Walls is something you don't want to use lightly.
  • LeanneZ
    Originally posted by jbenoit44 View Post
    you can right-click on a wall and select all instances visible in view.
    Oops! I was gonna post that, but I got side-tracked. ;-)
  • jbenoit44
    you can right-click on a wall and select all instances visible in view. or select everything and use the filter. or select by types using a schedule (see my post WYSIWYG in French corner).
  • François
    So we always need to select the walls. Does it not possible to select all the walls thanks to the arborescence (on the left of the screen)?
  • LeanneZ
    Select all the walls first. Then the "Modify|Walls" tab shows up. Choose "Detach Top/Base." After that, on the options bar you get the <Detach All> button.
  • François
  • mdradvies
    Select them all and Detach Base?
  • François
    started a topic disconnect top and bottom of a wall
    Hi!
    Does someone know if there is a quicker way to disconnect all the walls at one stroke instead of disconnect the walls from the slabs one by one?
    Thanks,
    François
