Grid Lines Visibility Mystery
    Hi All,
    I modelled horizontal & vertical grids for a 3 level project with uniformed floor to soffit dims.
    For each view :-
    • My view range is the same
    • All modelled and Annotation elements are set to visible
    But the grids (in both directions) are only visible on Level 00 & Level 01. Level 02 however only has vertical grids, but the horizontal grids have disappeared.
    Any reason as to why this happened and any soultions i can adopt to rectify this mystery?
    Assistance is greatly appreciated.
    G
    cut a section or elevation showing the grids, I'll bet they do not extend to the upper floors.
    Rob Pivovarnick, AIA
    Senior Project Architect
    Michael Graves Architecture and Design
    LinkedIn Profile | @ Twitter
      A simple way to fix this is to select the Grid, then right-click and pick "Maximize 3D extents"
      This will ensure that your Grid will extend above the highest modeled element.
      Dave Plumb
      BWBR Architects; St Paul, MN
        or create a scope box with the correct 3d extents and associate the grids to that scope box. I do this a lot for grids that are curved or non orthogonal to any view.
        Brian Mackey |BD Mackey Consulting
        www.bdmackeyconsulting.com/blog
        @Twitter
          Thanks all for the advice and support, all sorted now using the 'maximize 3d extents' method.
          Much appreciated.
          G
