Rebar Schedule element not showing
    I have created a schedule to show all the rebar in a particular slab along with the stand parameters.
    BarMark
    Type
    Shape
    Quantity
    Bar Length
    A
    B
    C
    etc
    However some of the shape 00 bars are not showing there 'A' even though the Barlength shown is correct
    Anyone got any ideas?
    is the schedule "Itemizing" every instance? I would start there because if it isn't that would be the culprit.
    Brian Mackey |BD Mackey Consulting
    www.bdmackeyconsulting.com/blog
    @Twitter
      That would not help unfortunately
      I have multiple instances of each bar mark - so for example I have a 2 range of 2m long H10s one with 8 bars and one with 6 bars.
      I want this to appear as 14 bars
      Which is what I have it set out as currently
      However as stated before the A dimension isn't displayingScreen Shot 2014-12-19 at 11.19.09.pngScreen Shot 2014-12-19 at 11.19.09.png
      as shown in picture
        SOLVED
        It appears even if you have the rebar settings set to round rebar to 5 mm the schedule does not
        My blank areas were where I had bars that were the same bar mark and the length of A had been rounded
        However in the schedule it doesn't round the values - so appeared as blank - because there were multiple values for A
