In a 3D view (largely an elevation) I've got a surface and stepped concrete walls - SOME of the foundation walls trim to the surface (don't show below it), others do continue to display under the surface, with a different color. Can't figure out what I did right, or wrong. Also the 'horizon' generated by the 3D view is below the surface, the surface actually casts a shadow on this 'horizon'. Can I override or manipulate this horizon?
thanks, Will
thanks, Will
