Changing the color of dimension lines
    Is there a way to change the color of dimension lines? I may have over looked it but so far I have not found a way.
    Thanks in advance.
    Highlight a dimension line, in Properties, click 'Edit Type',
    duplicate the original and rename,
    look in the Type Properties for color and change it to what you want.
    Hope that was what you meant.
    William Sutherland rias riba
    WS Architecture Ltd
      That is perfect thanks!!
        Is there a way to change the color of dimensiontext? I may have over looked it but so far I have not found a way.
        means dimension line
        color black and text color will be red
          Nope, one color for everything.
            thanks
              Is it possible?
                Originally posted by NijamKareem View Post
                Is it possible?
                min text count
                chad
