Tag A Soffit?
    Tag A Soffit?
    OK, so this intrigues me a little.
    We have this tool available in RAC to create a soffit to a roof. Great. Works well enough, well that is until you go to tag them.:banghead:
    It seems that soffit's cannot be tagged in the model. Is this correct?
    If that is the case, how do people tag soffit heights and materials in their projects? Do they just use ceilings instead?
    What is the point of having the soffit tool if you cant apply information to that element?:crazy:
    Andrew Harp
    BIM Manager GHD
    Alas it is true - there is no soffit tag. :crazy:
    I use a generic annotation label, but have also used a modified keynote tag also. I could never get either to show height like a ceiling tag - and have since started to consider differentiating ceilings by an interior/exterior parameter and just use them instead of the soffit tool.
      I've always just used ceilings for these reasons.
        We use ceilings, too.
          Yup. 67890
            There's no soffit tag, neither is there a fascia tag, nor a wall sweep tag.
            The only way to do this is creating custom shared parameters (type, text) and apply that to all these kind of categories. Then you can tag them.
            Height and stuff isn't possible though. Height can only be tagged using the spot elevation tag.
              It's been a while since I've actually had to tackle this, and so haven't needed to review if it's been included in either 2011 or 2012, but seeing as there's a great majority of you using ceilings for soffits, does that mean ceilings can now have more than one edge defining slope? If not, what do you do with hipped/valley soffits? Paired/multiple elements/sketches?
              • Parametric tag
                Hello,
                i'm trying to do this tag parametric (hight of roof, ceilings, floor etc) but dont know how, does any body knows if there are an existing...
                August 2, 2014, 03:01 PM
              • 'sloped' tag
                What kind of setting is responsible for this behavior? When the leader consists of only one line the tag is placed in the same angle as the material,...
                July 4, 2011, 01:12 PM
              • Tag Help
                I am trying to tag my structural elements so that If I ever need to change them, I won't have to change the annotation. My problem comes when I have something...
                May 13, 2013, 06:37 PM
              • Revit OpEd: Tagging Elements
                It is pretty common to have quite a few different kinds of tags for the elements we need to tag in views. Some equipment might get an oval shaped tag
                August 6, 2014, 01:45 AM
              • Ceiling Tag rounding
                Is it possible to have the height of a ceiling tag to round? For instance, if the bottom chord of a truss was at 9'-0" with a sheet of 5/8"...
                August 10, 2016, 08:08 PM
