Elevation Tag Location
    Does anyone know how to move elevation tags independent of views? I would like to have them in a site plan as well as floor plans but when I move them in floor plan view, even if I select just the circle, not the arrow part, the elevation tag moves in all the views.
    I do not think you can do this since they are technically the same object, shown in different views, although probably (hopefully) at different scales.
    I think you should be able to place new elevation tags and reference the other original elevation views to accomplish what you wish. You can use the "Hide at scales coarser" setting to control one or the other set of tags depending on your needs.
      Ok, thanks. I think I'll just hide the elevation tags in the site plan and just show them in the floor plans.
