Elements on View Workset
    I have a model from a hotel brand (i.e. built by others and I was told not to rebuild it :banghead and it is an absolute mess, to the point that about half of it is on view worksets. Based on what I've read (links below) the solution as of 2013 is to copy / paste to same place. However there is an unknown amount of documentation associated with these objects and I'm a bit hesitant to just start nuking things since I don't know what I will end up losing. However - If I select these objects I can change the workset in the properties palette. Is this the fix or are there issues that I'm not seeing by doing it that way?
    Model Elements on View Worksets - The Revit Clinic
    http://www.revitforum.org/blog-feeds...-worksets.html
    http://www.revitforum.org/architectu...-worksets.html
    chad
    I had a similar problem a while back and was able to use Ideates Explorer tool to speed up the process of filtering and then moving elements to proper worksets. If you have similar tool it will help. There probably isn't a good shortcut that won't cause bigger problems.
      If it is as simple as changing the workset in the properties palette than I'm good. I just don't want to try and track down god knows how many annotations if I have to copy / paste per the links =/
      going to a 3D view and turning on workset display is pretty quick as well.
      chad
