New Pop Up Error
    New Pop Up Error
    All,
    I have a new Pop up i like to share with you.
    see attachment
    1 is what i get when i try to save to central.
    2 is when i try to check workset.
    it let me save to local.
    Seems like you saved to central at some point without saving your local file and then closed the local. So when you opened up the local file again it did not have any of the changes you made before your SWC. Therefore Revit has no way to reconcile that. You are probably going to need to make a new local.
    Rob Pivovarnick, AIA
    Senior Project Architect
    Michael Graves Architecture and Design
    LinkedIn Profile | @ Twitter
      your going to have to make a new local file from the central file I would not do any work in your local file getting these errors as they will not save back to central and will be lost when you create a new local model
      always save to central then save to local
        Make sure no one is in the Central model as well.
