How would you model this?
Corner Panel Model In Place
Hate that.
It's just like corner windows.
No straight workflow.
Just trick and I hate those.Gonçalo Feio
I'd go with a Generic Model. You can make those parametric. And save and reuseMartijn de Riet
The in place was started by someone else, and due to time constraints I didn't rebuild it. :-\.... basically..... Just questioning myself on if I could model it better in a different way. I was thinking of using a nested family for the wire panels. I could control the angles better this way.-Alex Cunningham
I'm trying to create custom corner curtain wall panels using the Curtain Wall Family.
I have been having some issues with...-
May 22, 2017, 03:16 PM -
How do people handle the corner conditions of their radiant panel families? (Specifically for mitered corners). I want to have my rows be an array but...
Channel: MEP - Family Creation
January 8, 2016, 04:08 PM -
Hi. I'm trying to add a 2-phase panel (so only show A & B in the panel schedule) but I'm not sure how to go about it. First off, I understand I need...
Channel: MEP - General
July 14, 2015, 06:17 PM -
Someone needs to build one of these for Revit:
DIY Overhead Control Panel - Album on Imgur
(found via Lifehacker)
Channel: Out There
August 24, 2015, 01:45 AM -
Hi everyone. From a quick search around it doesn't seem possible, but I was wondering if anyone here has found a proper workaround for creating a double...
March 14, 2017, 10:19 PM -
