There are times when we'd like to alter the 2D (view specific) position of Grids. When you select a Grid you can click the 3D icon to toggle it to 2D. That's a one-at-a-time affair though. If you have many grids you won't look forward to doing that.
When a Grid crosses a crop boundary in a view (when the crop boundary is enabled) it switches from 3D to 2D automatically. If you want to enable the 2D setting for all the vertical grids at once turn on the view's crop boundary and make it crosses your grids.
Now you can adjust all the Grids end point position together just like they do automatically for the 3D setting. It will work for levels too. If you don't want the crop region long term you can just disable it afterward. The Grids or Levels will retain their alteration until (if) you elect to use the Reset to 3D Extents (right click context menu option).
