I need to rotate a building, and move it 1.1metres. Rotation was surprisingly easy. Moving the model seems to be a completely different beast.
When using the Relocate Project tool, I can move my building 1.1 metres. but that also means the project origin, as well as the PBP, are moved 1.1m. These are my reference points, and very important. I can unclip the PBP and move it 1.1m back. Unfortunately, this doesn't move the project origin. Suddenly the "link CAD by origin" and "link revit by origin" no longer work.
I've looked into using "link by shared coordinates", but that process seems sketchy. I'd really prefer it if my origins in all files (15 of them) could be consistent. Am I out of luck here? I see my options right now as being:
a) Move the PBP 1.1m, and sacrifice the consistent origin across files
b) Manually grab all the geometry in my file, and drop it where I need it, but causing a mess when certain lines (annotation lines?) don't move.
