I am having a lot of trouble with something that should be an easy task. 2 walls of an adjacent masonry 'shed' type building will not join. The N wall joins well with the E wall, but the S wall has a mind of it's own. The dimensions of the E wall are grayed out so I cannot change it's length. I have redrawn the S wall multiple times with the same result. It also does not want to move. (Maybe it thinks that it is heavy masonry or something.) I could use a little help. What am I stuck on?
Joining Adjacent Walls - Help
This topic is closed.
Thanks Alex. The file size (2.52 MB) exceeds the limit allowed (1.95 MB). So here is a perspective view with the trouble wall highlighted. This should give some clues (I hope).
The N & S walls are angled at the top. I have had to change the heights many times because they seem to shift after I close and then open it. The heights are correct
How do I look at the cut view?Attached Files
Hi, the fastest way to help should be:
you may delete the W wall, edit the profile of the E one, check the height at start/end.
then apply the height you checked to the S wall. after that use intersection of walls to get the result you want.
At the end mirror the E wall, and check again intersections with the S one.
Also check if one wall is pinned (if so just unpinned!).
good luckJulien
P. DAC
Hi All,
Im new to the BIM world and I'm having trouble trying to sort out the intersection between two different cavity walls. If there is...July 8, 2013, 05:56 PM -
I've recently decided to go full-on with Revit, rather than dipping my toe in out of it, and I'm enjoying making some (slow) progress. But I keep getting...April 6, 2018, 09:28 PM
Hello world,
I am starting a new project that will be mostly steel construction but there are some Integra wall systems walls that I...-
March 1, 2018, 05:13 PM -
Hi all,
I am facing some troubles in wrapping the compound walls.
Firstly, here are the components of the compound wall:
...February 24, 2018, 12:27 PM -
I have got a quick question being that the entire course of this project i have had countless issues with wall joins and i am back on it for an addendum....February 12, 2013, 01:23 PM
