Rendering in Revit...
    Hello everyone...
    Really i`m new in Revit, I`m trying to make rendering but the output was unrealistic.
    It seems i must developed Rendering and Lighting settings... anyone can put me at the road in rendering
    i saw many lessons about that but it was difficult to make a "real scene" with a good lighting...
    thank you...
    Hi Sami.
    Have you read Juans post here ?
      Just a word of caution is to double check if using 2012 because when I tried the same settings there, the results were very different than expected.
      Juan Carlos Moreno
      Sisley Cosmetics
        Originally posted by Munkholm View Post
        Hi Sami.
        Thank you Munkholm... I used it but the result wasn`t acceptable It seems some options must be done before ...
        and ... i`m trying
          Sami, to give you any valuable input, you´ll need to provide us with one of the "unacceptable" renderes, and tell us more about what you´re doing, and in what ways you´re expecting to improve it.
            Im trying to make render in revit but the main thing for me that i can`t see anything from the scene unless i add artificial lights for interior (about 18 lights)...
Name:	3D View 3.jpg
ID:	371404 Draft with 18 lights
                You don´t have any windows?
                Interiors are hard (but not impossible) to do, especially if you need to rely only on artificial lighting.
                If you don´t mind a bit of daylight coming in to the scene, you could apply a "Section Box" to the view, to cut away everything behind the camera.
                  Munkholm... my problem in the file attached
                  Very dark when i use artificial only
                  Very light when i use sun only ... of course i made this quickly to show u
                    You probably need to turn up the "Wattage" on your artificial lights... Those have to be unrealistic high from my experience.
                    In both cases, you should try to play with the "Adjust Exposure" settings after the Render is complete... Can work wonders sometimes
