OK, this is a bit of an old problem that I feel I should just know how to do but always comes back to vex me. In the attached massing model I have several roofs that I wish to simply "clean up" where they meet so that when I look at the floor plan and section they appear as all joined together. In other words, I'd like roof 1 roof 2, roof 3, and roof 4 to all be joined with no overlap internally.
If I try to use the dormer opening tool I always seem to get the "Dormer Opening Cut is not fully defined" message. And I've had problems with the other "cut" tools as well. I'm sure there is a fairly easy way to do this so any advice would be appreciated.
I'm not concerned with the structural accuracy of showing one overbuilt section vs. another (hence having all clean roof intersections) as I do my structural plans using a combination of linework and the model. I just want a clean slate on the floor plan..........
Just so you know, roof 1 is the existing roof. All other roofs are being added.
Thanks,
Dean
Thanks,
Dean
