Stair doubt
    Stair doubt
    Hi All, I need to model this stair, I know that it seems not difficult but I don't figure me out how I can model the part that's marked in red, any suggestions will be very much appreciated, regards.
ID:	410886 Click image for larger version
    E.A Poe
    For both instances I would:
    In-place component (category wall)
    sweep (path drawn across the width of the stair/profile to underside of stair as you see in the images)
    If you want a monolithic appearance as per the images make the material of the wall/stair/in-place components the same and use the join tool.
      It can be done with three separate stair objects, however imho, it’s a pita – not worth the effort.
      You’ll be better off just creating triangular shape extrusions underneath the stair for top and bottom, in-place or family.
        Tnx BLothian, in fact I figured out that way, but my idea was to do the stairs using stair command because my client needs to add rebars and It's necessary to export the model to IFC too, so I don't know what consequences modeling the stair as a wall can be, but I'll gonna do the stair following your advise I think I don't have any other option, best regards.
        E.A Poe
          Thanks PijPiwo, it's a good Idea and yes is a pita, but anyway I should deliver the model tomorrow, so I think I'll model the stair as you proposed, best regards.
          E.A Poe
