How to show same section in different places?
    I need to have those two detailed sections showing how to construct. How can i set same names for them? or is there any other way to do it? for instance " name " and " name' ". Or should i make note on drawing that would state that they are the same?
    One of them shouldn´t be a "Real" section, but instead chose the option to "Reference other view" when placing the second "section", and pick the first section as the referencing view.
      Nice and easy, smooth and beautiful. Thanks Danish man!
        I don't know about all that...most would say they would like some improvement on these. Once you reference a view you can not change the reference, you have to delete and remake.
          Just to point out something.....grid lines are supposed to be straight, no angles...
            More troublesome is a project with 2 phases, where you may want to have a section view for both phases, and have them be the same name (since they are in the same location). I use a break in the section tag label, any other ideas?
            There must be a better way...
            Ekko Nap
              ekkonap, they can´t have the same name, but they can have the same title.
              You can also play with types, parameters and filters when phases and views get confused.
              Gonçalo Feio
                And not reference the view name in the label, but some other property? I rather like my view references and view names to look alike. But it's an option I suppose. Tnx.
                but I sort my views by phase as well, no need to get confused there.
                Ekko Nap
                  It's not all about sorting, but also to hide them.
                  In Portugal, where I come from, it is required to have existing view, proposed alteration views and color coded views with what's demolished and what's new.
                  These color coded views usually also show up in the final phase view. I use a filter to hide them, so that they are only shown in the color coded plans.
                  If the views are of different types, they can share the same name, but that can be harder to manage.
                  Gonçalo Feio
