Light Fixture Annotations not rotating
    I am trying to edit the light families at a company I've just joined. On the families everything looks ok with the annotation but when I bring the view into a sheet everything is a bit all over the place. All "rotate with sheets" and "keep readable" are checked but nothing seems to be working. I can't really issue a drawing with the light references upside down!
    Thanks
    I'd use tags instead. If that's not an option, can't you just rotate the fixture 180 degrees?
    Dan
      I would also make those into a lighting fixture tag(s). You may have all that checked but if the person who placed them, rotates the family during placement or after it will change the location of the annotation and those check boxes doesn't matter.
      Jason Peckovitch
      Father | Photographer | Car/Tech Guy
      Revit MEP 2015 Certified Professional
      That BIM Guy Blog | Google+
