Go to the section and try to dimension column! it crashes.. any suggestions?
Error in RAC2011, any suggestions? project file attached
No crashes here - was able to dimension height of column. Try deleting the section and creating a new one.Ian Kidston
http://allextensions.com.au
I've open the file in RST 2012, no crash; but what is weird is that i can dim the height of the column but not the width in cut view.
you have to be carefull with rotated objects when making cut views, you'll be able to dimension only if the view is perpendicular to faces.
I use personally a ref plane to be perpendicular to faces then snap my cut view to this plane.
works fine for instance in elevation view. bug are you here???Julien
P. DAC
I have had this issue with elements not being perfectly square to the view plane. I ma not at my PC right now but if you check I think you might find the column is slightly rotated from the view plane.Andrew Harp
BIM Manager GHD
I'm having trouble aligning a column that is sloped in two directions. (see image below)
The column is sloped in both the X and Y directions and...October 14, 2015, 05:07 PM -
red colored is the linked rvt w/ one GM instance which imported SAT converted from rhino, well, for cuttable reason.
how to cut off extra...May 14, 2015, 03:08 AM -
I have been trying to create a new family for circular column with a circular capital. When I try to flex the dimensions, it does not work. However, when...
June 5, 2012, 12:42 AM -
We are pretty new to revit and i have been given the job of learning and spreading the knowledge around our company. The question i have is how are column...
July 17, 2014, 03:44 PM -
I have a problem with my columns not showing up in my views.
Please see attached 2 images.
The column is not hidden...-
November 5, 2012, 03:00 AM -
