scale label with multiple views on sheet
    Got a question but I almost know the answer: when placing more than one view on a sheet, the Scale label in my titleblock family indicates "comme indiqué" / "as indicated" in US version I guess.
    Does someone know if it could be changed/hidden?
    thanks.
    Julien
    P. DAC
    Nope, it´s hardcoded as you guessed... But at least you guys get a French translation. My clients are forced to read the English text
      Forgot to mention:
      You could hide or replace the text in the Titleblock with visibility parameters (Yes/No) - But it will be a manual process, and will not be automaticly coordinated...
        Correct, best you can do is have a visibility parameter that toggles the "Revit Scale" off and turns a custom scale on
        Funny because that is actually one way I use to tell if a set of drawings are are Revit, because no one else would have "As Indicated"
        Revit BLOGGAGE
        http://www.revic.org.au
          Why would your clients need the French translation..?
            They don´t need French translations, but they don´t need English either... that´s the whole point - We should be able to change the text in hardcoded fields like "As indicated" - Surely it would be pretty easy to include those in the Revit.ini (or similar file) allowing us to change the output
              I guess this would be a bit against the nature oh hardcoded values.
              [email protected]
              http://4revit.com
                Irony is a b***h... Would be nice though to have it.
                  Irony is a b***h...
                  Here it´s the b***h who does the ironing... :laugh:
                    You're really confident she isn't lurking around here are you... :hide:
