I've run into an issue with 2014, where some of my views show no geometry when opened. It's there, but the view is panned away from where it was created. I zoom extents, and there everything is. The next time I open the view same thing. Panned away from the model. Is there a setting that allows for the current view extents to be saved or reset? Thanks
Unsaved veiw state
when you open a Plan View, Revit will try to zoom the new View to the same place your last plan View showed. Helpful when you're opening two Views on the same floor. Sometimes not so much when you open a different floor.Dave Plumb
BWBR Architects; St Paul, MN
Is there any way to set a view's default view? It seems like this must have been answered at some point but I can't find it anywhere. When I open some...January 19, 2016, 12:52 PM
I have a file with a lot of views and have been organizing them according to name and template usage.
Each time I go to a view I use the "zoom...October 7, 2014, 11:41 PM -
I wrote THIS POST about Revit's behavior when you open a new view. There are times when you open a new view and Revit seems determined not to show you...
Channel: Blog Feeds
July 31, 2014, 05:15 PM -
Am I going batty!!?!
I am used to Revit opening a view of the same scale to the same location as the currently open view. So one can switch...August 5, 2019, 09:21 PM -
This is an echo of something I wrote in 2011....
If you are in a plan view, when you open a new floor plan view (any "plan" view)-
Channel: Blog Feeds
October 25, 2013, 11:15 PM -
