Image Will Not Plot
    Image Will Not Plot
    I have a image set in a perspective view and the image will not plot to pdf or our large format plotter. I applied the image to the view using Graphic Display Options and set the to a custom image.
    I am using 2015.
    Anyone else having this issue.
    Jason Coe, Architect
    Beardsley Architects + Engineers
    Auburn, New York
    http://revitecture.blogspot.com
    Try changing file format -- i.e. .png, .jpg, .tiff etc and see if anything changes.
    Also, try changing print setting from vector to raster or vice-versa.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      Seems it's been an issue for quite a while:
      https://forums.autodesk.com/t5/revit...l/td-p/3822400
      http://www.revitforum.org/architectu...ackground.html
      chad
        Try what's been said above, but I've never had this problem. What printer are you using? Latest drivers?
          Change vector to raster in the print dialogue.
