Hi, I have to render a mountain (and insert a bridge in it) and can't achieve a good result with Revit texture's... it never looks realistic: a mountain doesn't contain only grass or one color, it should have different tones and colours... can anyone help me with this? Any tip? Any miraculous texture? Thanks!
Rendering Terrain
Terrain Rendering
the trick is to get a google image of your site(if you have google proffessional you can save at high res.). Then use that as the material for you landscape, you also want to make a bump out of the image. See attached, all the is straight from revit, using the google image for the material.Scott D. Brown, AIA | Senior Project Manager | Beck Group
Yes its a large image, 1 mile or more square approx. 30mb jpg. Then its applied to the material of the toposurf. and a bump is made(grey scale). I can't remember which material type gave me the most bump value. I did the same for the sand under the water.Scott D. Brown, AIA | Senior Project Manager | Beck Group
Originally posted by sdbrownaia View PostYes its a large image, 1 mile or more square approx. 30mb jpg. Then its applied to the material of the toposurf. and a bump is made(grey scale). I can't remember which material type gave me the most bump value. I did the same for the sand under the water.
for those of you not familiar with creating bump maps:
Make a copy of the texture, call it texture_bump (or something like that).
Open in a Photo Editing Program (standard windows app will do)
Edit so it turns into a grayscale picture. The more contrast in the picture, the better the depth in Revit.
Save and close
In Revit: open the material editor and choose the terrain material. Then go to the Render Appearance Tab
Apply the original texture
Apply the texture_bump to the bump-texture under Bump (you may have to scroll or use the fly-out arrow besides Bump to see this material)
Don't forget the checkbox...
Have fun!Martijn de Riet
A really useful tool for creating maps of all kinds from a bitmap (and fixing tiling / shadowing issues with bitmaps) is Crazybump: http://www.crazybump.com/
You can use the demo up to a certain size of image for free. I use it all the time!
As for the site, if you don't want to go with the Google image idea (which is a great one) because of time constraints, you can create much better rendering textures by layering.
Revit 2011 allows you to change the default color to an image, but it also allows you to set it to other more complex things, like Noise.
Noise takes two colors and mixes them together randomly, with faded edges and such so that you get a 'TV Static' kind of result.
Thing is, you can then tell Revit to use Bitmaps instead of a solid color, and it will mix the two bitmaps together.
So if you make a Noise, set the scale to be rather large, and use two different bitmaps (one of grassy site and one of rocky dirt) you can begin to get a better looking default site material that you can throw at anything.
You can even have the Noise have Noise, in that the two elements being mixed can themselves be Noise.
There are also Wood and Marble and other Procedural Shaders that you can layer together to make more complex materials.
I'll try to post an example when I've got time to do so!Jeffrey McGrew
Architect & Founder
This is a quick exterior rendering. 100% revit, no photoshop....
Channel: Rendering and Gallery
November 1, 2011, 09:40 PM -
Hi , Thanks to all people here giving me their suggestion and tips to improve my rendering outputs like cliff collins Dzatto, sdbrownaia, Munkholm, and...
February 19, 2012, 11:48 AM -
I have Dell T1500 Workstation with following configuration.
Intel i5
4GB Ram
Windows 7 Pro 64bit.
1GB Quadro600 Graphics...-
Channel: Hardware and Infrastructure
December 5, 2011, 04:32 AM -
We've been using revit to make quick renderings of projects which works fine. We now need a high resolution rendering to be used on a construction site...October 8, 2018, 02:00 PM
hi, this is my project.. a renovation house of my family friend. all modelling and rendering done in revit architecture 2010. i made this last year. i...
November 15, 2011, 07:48 AM -
