I have created my Company Title Block which contains a Revision Schedule. I inserted this Title Block into my Project and all was fine. But now when I insert my Title Block again or click "New Sheet" and add my Title block it brings it in but the Text on the Revision Schedule is huge (as the pictures illustrate) The Title Blocks I originally added in remain fine, just any new ones I add. Does anyone know what is going on? Thanks.
Title Block question
Did you get any messages about the TB being renamed? i.e. TitleBlock_24x36 is renamed to TitleBlock_24x36 1? Once the family is in the project you shouldn't need to reinsert it again unless you are modifying something in the family. If you did get a message you should be able to select all instances and swap them to the correct version.
Here's a probably elemental question for anyone who's been using Revit for longer than my 1 month:
How do you update a title block? I've edited...September 21, 2011, 05:27 PM -
In acad it is possible to 'replace block with block'.
In Revit I would like to replace a title block on my sheets with another without...May 3, 2012, 10:11 PM -
Is there anyway to copy a title block multiple times that has the information filled in....project, status client etc
Thanks-
July 29, 2016, 08:44 AM -
I just been creating a title block and have done lines and text, added logo.
but when I come labels some act differently.
when I insert title...April 7, 2016, 11:23 AM -
I need to save my file as a new central and replace the title block with a new one.
how can i do this so that all sheets' title block will be replaced...January 29, 2015, 01:41 AM
