Hi guys
Hopefully posted in the correct place, can anyone shed some light on creating a specific formula to help choose from a different number of options in a text value.
Basically, for a schedule to work, i need a shared text parameter to display a certain value (either fitted-POST600 or fitted-POST700 or fitted-POST750 etc etc in a text field).
I'm looking at some way trying to have this value determined by another parameter (_ports_depth) which is a length parameter. So basically I want to be able to change the depth value to either 600mm, 700mm, 750mm, 800mm or 850mm and have the value output into my _Ports_Item text value.
I'm positive there is a way of expressing this by way of a formula but as a new user of Revit, I'm unsure of exactly what expressions are to be used.
I've attached a screen shot of my family type which might clarify what I mean!!
Cheers!
Cheers!
