I had FM (or finally I changed that to FE) for "Finish Model." But that was under the In-Place Model Tab within the Keyboard Shortcuts dialogue box. That no longer exists. I cannot find it nor what I assumed might be its replacement. I aslo tried importing my old RAC2011 settings, but that particular shortcut did not take...
Can't make a keyboard shortcut in RAC2012
Originally posted by bangobeat View PostI have also few problems in RAC2011, cant make shortcut to ref plane, tried many shortcuts but it doesnt work properly sometimes..
Originally posted by narlee View PostI had FM (or finally I changed that to FE) for "Finish Model." But that was under the In-Place Model Tab within the Keyboard Shortcuts dialogue box. That no longer exists. I cannot find it nor what I assumed might be its replacement. I aslo tried importing my old RAC2011 settings, but that particular shortcut did not take...Originally posted by mark b View PostSome commands still will not take shortcuts this one of them. Most annoying.
it seems you are correct, "finish edit" is readily accessible but "finish model" is not. that blows.
Also, it is not possible (2011+2012) to create keyboard shortcuts for all of the sketch line tools when doing an in-place model, they need to be manually selected. very annoying :banghead:Last edited by elton williams; June 13, 2011, 02:19 PM.There are no stupid questions, only stupid people
Originally posted by narlee View PostIt seems like they were intending that functionality, because they show those commands in the Keyboard Shortcuts dialogue, but when I assign those sketchlines modes shortcuts, they don't take in Revit. Is that what you mean?
in KS, select "contextual tabs" in the dropdown, type "line" into the searchbox, look for "contextual > draw" paths in the RH column. They're all there and they all work.
The terminology used in the KS dialogue for a lot of these shortcuts can be confusing as it doesn't always match what we see in the project environment.There are no stupid questions, only stupid people
Hi All
I've just discovered this great shortcut 'BX' someone showed me a shortcut for elevations that performs the same action but I can't...August 11, 2017, 08:56 AM -
I have two CommandIDs, ID_FINISH_LEVEL_LANDINGS_EDIT & ID_QUIT_LEVEL_LANDINGS_EDIT, and I'm trying to match them to buttons. Or verify that they are...February 6, 2019, 07:53 PM
Okay, this has been happening for a while, and I can't take it anymore. Both my laptop and my workstation, running 2013 Revit (aka one box). All shortcuts...August 10, 2012, 07:11 PM
hi,,
Recently I am trying to use the keyboard fully due to hand pain. I have realised some places I cant utilize the keyboard where...-
June 30, 2017, 06:10 AM -
I've been using Revit for a number of years now, I was using AutoCAD and have not been needing to use that anymore
When I was using it I had...April 14, 2017, 02:58 PM
