In the olden days, we used to differentiate existing and new building elements with a line-based hatch to denote the material and a solid hatch in the to indicate new elements.
I think revit cannot achieve this in one view, a cut element either gets a pattern by material or by some view, phase or category override. Am I right so far?
Solution then is to stack views on a sheet, with the cut pattern by material in one and the cut pattern by some override in the other. The top view needs to be transparent.
Turns out that a standard solid pattern does not show if the element is set as transparent (or the view to wireframe). No problem if all your material cut patterns are line based. Even solid patterns can be simulated with a hatch pattern that draws very short lines (test your printer settings and lineweights though!). Transparent line based cut patterns by material on top, solid overrides on the bottom. Or is it?
Yes it is. Transparency shows surface patterns in cut elements, families can have deviating settings and field regions with solid hatches need to be moved to the bottom view. In the end your drawing elements are spread out over 2 different views, and what belongs where is not immediately apparent.
I'd rather have as many drawing elements as possible in one view, with as few view overrides a possible in that view, allowing me to edit my model and annotation there, and have one view containing the overrides. Ergo, this last view needs to contain the transparancy and the solid cut patterns. 2 solutions;
1: Use forementioned point hatch pattern in top view with a transparency override/wireframe. Issues: interference with similar patterns in bottom view, newly introduced categories will not have the overrides.
2: Use a thin 3D view. 3D views allow transparency by material. Issues: not all overrides can override with another material (I think only phase overrides), you need to remember to save the 3D view after creating the slice.
In short: your opinions on best practices for using stacked views?
Credits to MdR for pointing out the transparency by category override (Dutch forum).
Edit: none of this prints correctly with vector settings by the way.
