This thread does not contain a question, just maybe you will find family (a small rectangle on the sheet) in attached project interesting. Although maybe the trick has long been known.
Annotation symbol with grips.
Interesting. I wonder how they came up with this family, since a generic annotation template does not let you create more reference planes but only reference lines. I notice that the bottom line does not flex, though. This family might be a solution for another thread in which a user from the UK was trying to create a custom section symbol to be used over key plans on sheets.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Alfredo, I just posted a similar solution to that thread you're referencing. Turns out that if you start your annotation family with the Section Head template, you get your third reference plane. I also found you can copy/paste a reference plane from one family into another family. I'm curious to see how Nurlan made this one and if there's another way...Last edited by need4mospd; June 10, 2011, 12:08 PM.
Yeah, I know about the head section template, but how do you manage to create the fourth reference plane?
EDIT: ah, by copy/paste from another family? really?Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Unfortunately I do not remember exactly how it did because it was long ago and I did not attach any importance to this. Then I just started learning revit and tried to make the title block and via changing the categories and groups, and somehow put in a reference plane. So that ignorance and randomness can be creative.
And yes, you can copy paste these planes in any annotation family.
I'm glad you enjoyed it, I think it will help to create useful families.
Cool tip! More Rep!Martijn de Riet
Originally posted by need4mospd View PostAlfredo, I just posted a similar solution to that thread you're referencing. Turns out that if you start your annotation family with the Section Head template, you get your third reference plane. I also found you can copy/paste a reference plane from one family into another family. I'm curious to see how Nurlan made this one and if there's another way...Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Originally posted by Alfredo Medina View PostHold on... In this case, creating a family starting from a template that was meant to be used for something seems to have some consequences. The family posted in that other thread does not really flex. At least here, when I click on the blue pull arrows to stretch the length of the symbol, it actually increases the size of the line on both sides in a very strange way, making the solution not suitable for the purpose that was requested in that thread.
Hi friends,
I am working on an electrical family rig and am running into a roadblock on my symbol controls that I hope you might provide...-
June 9, 2019, 11:42 PM -
Hi guys,
Im a newbie to Revit and am having some issues already with content creation.
I have managed to create a socket...-
Channel: MEP - Family Creation
August 9, 2011, 06:37 AM -
I am creating an annotation family using reference lines and parameters. My problem is that when I set a dimension and parameter between reference lines,...
August 6, 2013, 01:59 PM -
Hi all. I found this trick to getting annotations to rotate, but I want to take it a step further but can't figure it out. Basically, I have a generic...
April 9, 2015, 05:22 PM -
Hi everyone
Im trying to place smoke detectors in my drawing on RCP view. They only show as a small red dot rather than the annotation symbol....-
May 22, 2014, 10:21 AM -
