When we generate an interior elevation and then place it on a sheet which also has another view on it (can be any view type), it is automatically assigned a view number. If we change the view number in the view title, the number in the View Title updates - but the number on the interior elevation mark does not. If we go in and edit the Type Properties of the elevation mark, making a slight change and then select "Okay", this seems to force the interior elevation mark to update. This occurs in files upgraded from 2011, including our upgraded template. Could it be a problem with the upgrade? Any suggestions are appreciated.
Elevation Tags Not Updating
Hi WV,
I am working on an old project created in Revit 2008. Opened and saved the file in 2012 format. No matter where I change the assigned number, it populates through the entire project as expected.
For no other reason than I can't think of anything else, try closing revit or even rebooting the computer and check if the problem persists.
Maybe others have come across this problem previously.
Edit: re Dan's post above.
See - RFO has the answers - didn't know the bug existedI had obviously moved the view on the sheet and hence no perceived problem
Ian Kidston
http://allextensions.com.au
Okay, this is driving me insane. I want to use the round interior elevations tag, but I don't want it to display the view name. I can't figure out how...March 1, 2011, 10:13 PM
Please just for general test outthere... In RAC 2012 I seem to have failiures in different RTE files. The Elevation View Tag is missing update on renaming...May 9, 2011, 03:14 PM
I would like to raise this question again because in one of my older posts I may have not explained what is the exact goal I want.
We...October 7, 2012, 12:27 PM -
For internal elevations, is there a way to have different titles shown on the elevation tags and different titles on the view title? For example I have...September 5, 2017, 05:49 PM
is there a way to know which elevation maker is related to specific elevation view using API?
in my case, i want to hide all unreferenced view tags...-
Channel: Third party Add-Ins, API and R&D
February 20, 2013, 07:24 AM -
