I am brand new to Revit and kinda stumbling my way through it, but I have a quick question. I am designing a 4 story building for my class and first set up my column grids, annotated distances between grid lines and then I set up my levels. My question is, is there an easy way to display all the grid line changes I made and annotated distances for every level without having to go back and do the same thing for every level? I hope that makes sense...thank you for the help!
Level and Grid Question
Couple of tips.
Create your levels first, the grids will actually automatically extend to the model extents, so if you create grids with only the default levels, you will then have to go back and change the 3D extents for all your grids
Once you create your dimensions, you can just select in plan, copy to clipboard, then use the paste aligned option to selected views. you can then select the other plans you want the dimensions in
In Revit Structure, how can you make different grids for different levels? Apparently, when you make a grid for a level, it automatically copies to other...
February 25, 2015, 06:18 PM -
I have a project with radial grids that are unique on every level (don't ask, that's just the way it is.)
ive generated all my grids from...September 7, 2017, 10:47 AM -
I thought this would work, but it didn't. It may not be possible, but here's what I did:
I have 2 structural grids set up, one on the...January 5, 2012, 03:50 PM -
Hi folks,
I would really appreciate your input on a hot subject in my office right now. (I'm working in an Electrical only firm.)
Channel: MEP - General
August 13, 2014, 01:18 PM -
How can you set up to show level head automatic to the right or left when you create new view. Seem like when you create new view some on right...January 18, 2019, 02:39 PM
