I'm using the filters to show fire rated walls in plans. It works great in coarse, the pattern follows the wall, but when we switch to fine the pattern no longer follows the wall. anyone know any work around.
Cut Fill Patterns - Filter results different between Coarse and Fine
Scott D. Brown, AIA | Senior Project Manager | Beck GroupTags: None
Do you by any chance have a different Coarse Scale Fill Pattern set up in the Type Properties?Martijn de Riet
We are using a filter to change the cut pattern for a wall that is 1 Hour Rated. It's pretty simple, and the filter works fine. The oddity that i noticed...September 14, 2016, 07:46 PM
Hi all,
Due to the great new addition of double fill patterns in revit 2019, I am reviewing my graphic standards for wall cut patterns. This...June 1, 2018, 05:20 PM -
Hello Forum
I'm currently trying to find a clever way, to override walls by filter with a fill color (Solid) AND a fill pattern.. I want...September 16, 2011, 09:19 AM -
So I was wondering if anyone might have an answer on how to create the smoke wall type shown in this image. You will notice that not only does it use...December 30, 2011, 07:31 PM
Hi.
I have a problem with the patterns in my model, when I look at the section cut the patterns shows up as they should but when making a...February 5, 2014, 07:55 AM
