We've just had a request from a contractor for our current Revit model, which is at about 75% through CD's. They are also requesting our model from the DD stage so that they can compare the two to see what has changed, what has been added, etc. Although I can't speak from a lof of experience because we haven't had a lot of requests from contractors for models around here, this one seems a little odd because of the need to compare the two. Any thoughts?
Contractor Request for Model - Comparing DD to 75% CD
Originally posted by LKeyser View PostWe've just had a request from a contractor for our current Revit model, which is at about 75% through CD's. They are also requesting our model from the DD stage so that they can compare the two to see what has changed, what has been added, etc. Although I can't speak from a lof of experience because we haven't had a lot of requests from contractors for models around here, this one seems a little odd because of the need to compare the two. Any thoughts?I'm retired, if you don't like it, go around!
Originally posted by Dave Jones View Postthey probably bid the project from the DD docs and now want to see how much more money the Owner owes them for all of the stuff you've added
Ask them why they want the comparison, and have an opened mind. have the owner participate in the meeting.
Our estimators in Pre-con will load a new model and an old model in to Innovaya. It will graphically highlight EVERYTHING that has been added, deleted, or changed. It just tells them where they need to focus their efforts, instead of basically "re-pricing" the entire project, which is what you are telling them to do if you ONLY give them the new model.
Less work for them = better project?
I would be very hesitant to give a contractor Revit models. The legal issues around the use of and liability associated with BIM are far from settled. I recommend that you give them drawing sheets for comparison. As stated above, it is common practice to issue clouded revisions showing the extent of any changes. If they insist on a model I would give them a 3D DWF.Scott Hopkins AIA LEED AP
Peikert Group Architects
Or do that. Honestly, i hope more firms keep refusing to share data. It makes Integrated Companies look that much better by comparison, because we play nice with ourselves.
The legal issues are virtually gone, because no firm worth their weight in paper is going to hand over anything (PDF included) without a file transfer indemnification saying the documents override anything they see in the model, which you probably made them sign as part of your front end anyway.
Sometimes it REALLY IS just about someone trying to do their job more efficiently.
Originally posted by LKeyser View Postthis one seems a little odd because of the need to compare the two. Any thoughts?
This last contractor made his shop drawings from my model...copyclip. I do the work, he collects the fee.
As long as you have a disclaimer or something in your contract covering you, I wouldn't be too worried."Keeping my view range hopeful"
Originally posted by Twiceroadsfool View PostThe legal issues are virtually gone, because no firm worth their weight in paper is going to hand over anything (PDF included) without a file transfer indemnification saying the documents override anything they see in the model, which you probably made them sign as part of your front end anyway.
If your model is purpose-built, by contract, for the GC to estimate off of, then I suspect that you would not be asking this question. As it stands, you are likely building the model primarily for generating CDs, the paper copies of which are the legal contract documents. Explaining this with both the GC and Owner present so that they can ask questions and have them answered will build good will, and show everyone that you are interested in sharing information so that the project has a better chance of success.
If you feel that you should be compensated for providing the model you can explain why. Obviously, there may be other things going on that might affect your final decision, but on its face, does not sharing the model really help get a better project built?
I also don't see the problem with sharing (if provided with a solid disclaimer). It just helps the GC. I do it all the time...
There are occasions where I get paid to share it. There are occasions where I get paid by the GC to provide multiple construction possibilities. It all depends on the situation. My advice would be to keep an open mind and try to expand your business... I usually tell the GC that I can hand it over as built, or he gives me the specs of what info he needs and I'll set the model up to best serve his needs before handing it over (against a reasonable fee that is). You'd be surprised...Martijn de Riet
I am not sure that you can rely on a simple disclaimer to fully protect you from potential liability involved with releasing BIM models to contractors. At this time, there simply isn't any case law that clearly defines the legal issues surrounding BIM. Just because a disclaimer was adequate for CAD files does not mean that the courts will come to the same findings with respect to BIM models. The legal similarity of CAD to BIM is not apples to apples. Releasing BIM models into the wild puts you in uncharted legal territory. Do as you please - we need lawsuits to go to trial so that the rest of us will have new case law and a new set of rules to go by. The very first BIM lawsuit was just settled last month (May, 2011), there will undoubtedly be many many more to follow.
A few quotes from attorneys and other industry pundits regarding BIM.
"Like other innovations before it, BIM is treading on new ground, figuratively and especially legally. Although an established and broadly-accepted design and construction production and coordination tool, BIM’s legal history is almost nil; in effect it is a legal Wild West until some general guidelines and benchmarks are set. As owners sift through the fact surrounding this case and what it all means philosophically for their projects, consider what this means for even more nascent and less-accepted industry inventions like integrated project delivery (IPD). The risk averse out there may want to wait several years for IPD’s legal watershed moment before diving in with both feet. "
"It is our opinion that BIM will not only change the way buildings are designed and constructed, but also the way the construction industry operates. Unfortunately, as with many legal issues, published case law will lag years behind project experiences in terms of understanding liability with regard to the use of BIM. For that reason, all parties involved must be mindful of potentially new risks while embracing a technology that may ultimately reduce litigation related to construction projects."Last edited by Scott Hopkins; June 9, 2011, 10:52 PM.Scott Hopkins AIA LEED AP
We finished up a large remodel project about a year ago for a federal agency. When we turned in our Record Drawings, the Revit model was not part of...August 31, 2018, 09:30 PM
What is the best way to lean on the Architect to share their Revit model? I got the Mechanical and Plumbing model and am trying to do final coordination...July 26, 2018, 01:13 PM
I have been dealing with an architect that refuse to document any changes in there model.
when i asked if they would be documenting there...October 10, 2013, 08:51 PM -
MEP guy with a business question here.
We just wrapped up a project where we replaced several large air handlers in a 30+ story high rise...April 29, 2020, 02:23 AM -
I don't know if it is possible, but it would be great if an .rvt could have an option of 'read only'. My thought is, that if a firm spends a great deal...May 7, 2014, 05:22 PM
