[All Verticals] - Callout view tag with View Name label
This topic is closed.
    Applies to: - All Verticals
    New Feature / Problem:
    A callout view tag will not show a view name. All other view tags do.
    I'd rather use view names than detail numbers to number my details.
    Workflow:
    add label option
    Benefits:
    not having to match the detail number in callout view tags to the view name
    Attachment comments:
    There must be a better way...
    Ekko Nap
    I'd like to add a description next to the callout tag (e.g. "ENLARGED RESTROOM PLAN" or "TOP OF WALL ATTACHMENT" or "FOR ADDITIONAL INFORMATION"). I'm a NOOB and not sure if a callout tag is the correct way to refer to a standard detail not directly linked to model geometry, but if that's a drafting view I'd still like to have a instance based description as part of the callout tag.
      I've wanted this for a long time, It's the only way you can make your sheet and view management correct.
      After making a plugin that writes the view name to the detail number I've finally found a hack that works:
      If you want the viewname to be available as a label start by making a section head annotation.
      create a label for viewname
      select the label and use the cut command
      change the category of the family to callout head
      then choose paste current view.
      It will paste the label for viewname into your callouthead.
      now your callouthead will report the viewname
      the same hack also works for a few other parameters labels of different categories
      good luck and happy revit hacking
        Works like a charm. POTM material in my book :beer:. I just love a good hack! tnx!
        Ekko Nap
