Where do you guys go to research products for a building? I've found that we're limited to either manufacturer's literature or paying for software like MasterSpec. Is there any netural source of information out there that I don't have to pay for?
Building Product Information
We have several sites here in Aust. that access to manufacturers and suppliers and their products can be gained via. I have found these fairly good to research through. An example is http://selector.com/au. The internet has certainly made researching and collation of technical data so much easier.
Apart from that is the technique of harvesting the exhibitor lists for the building and construction expos. Those lists always have website links. And the shows are always happening somewhere in the country.
And search for links on sites and organisations created by affiliated companies.
cheersMotorbike riding is one long bezier curve
WOOT! Seems that http://selector.com/au. is a great one. This kind of sites definitely will help for me finishing last semester because we need for every material description and technical data. Maybe some1 else wants to share? Biff respect 4 you! And welcome to outsanding forum!
http://www.arcat.com/ seems a good option for the US market.
You have specs, some Revit models and CAD details for guidance.Gonçalo Feio
Slightly over 6 months ago, I was approached by one of my associates over at Unifi with an idea. They wanted to engage in a detailed competitive...-
Channel: Blog Feeds
September 6, 2017, 03:45 AM -
hy guys i'm a new memeber in this forum ,,,actually i'm a second year master degree student - civil engineering departement working on a research called...
Channel: Structure - Interoperability
February 22, 2013, 10:58 PM -
This interesting article about "Google's Genie platform" was on the BIMForum SmartBrief today:
Secret Google Project Could Transform...-
Channel: Out There
October 22, 2013, 08:34 PM -
Is anyone out there using a common data environment? Basically using and linking data from multiple sources and platforms ie Revit, Asta, Cubit, Costex,...March 4, 2018, 05:44 AM
Depending on the tech circles you run in (or keep track of) you may have heard of (or even read) the following post that was made by a Googler who formerly...
Channel: Blog Feeds
October 18, 2011, 01:16 AM -
