Why my Spot Elevation show minus at zero? How can I remove it?
Spot Elevation show minus at zero.
Odd... Shows the - (minus) here, regardless of the "Show +" setting (RAC 2011) but only when annotating the level at 0.000 and not when annotating the Floor at the same level
You can move the level up by 0,0000001 mm to "fix" it... but that´s not really a fix...Klaus Munkholm
I've been working on RST2010 (20090917_1515(x64)).
Spot elevation is placed on level - shows minus, spot elevation is placed on slab - don't.
Tuned off "Show+" - nothing has changed.
Сhecked on same computer with RAC 2011 and on another computer with RAC 2010 SP2 - the same thing.
When I create project without template everything is fine. So I think it depends on the template, but from what exactly.
Sorry for my English.Last edited by Nurlan; June 8, 2011, 12:53 PM.
Guys,
why is my Spot elevation showing different value than what it shows in my level?
suppose to be 0'-0" but it is showing 70'-...October 8, 2015, 10:10 PM -
Hi! I need to put a spot elevation in a plant view. The problem is that I need the height to be referenced to a floor, not to a level. This is possib...
Channel: Tutorials, Tips & Tricks
April 25, 2019, 09:24 PM -
Hi everyone,
Is there any possibility to create a Spot Elevation in a box without detail lines?
In the attachment is the desired...October 11, 2012, 09:43 AM -
Can I create spot elevation with both relative and absolute coordinate (one above the symbol line other below)?
How can I do that?
ThanksJanuary 6, 2014, 04:40 PM -
Hi everybody,
Recently I took anybody else's model to finish it, I've noticed that the elevations spots give me different heights than my...July 21, 2021, 07:45 AM
