REVIT MULTI-SHEET/PLACEHOLDER CREATOR
This add-in was designed to allow you to easily and rapidly create multiple sheets or placeholders inside of your REVIT project.
The app will allow you to name and number your sheets, and either apply a preloaded title block to it, or simply bring it in as a placeholder.
Features of the app:
Check it out and give me your thoughts, the grouping option may be optional as i understand its more a preference than the norm. Curious to see if this little app can or should grow .. or if its done after 2012.
Installation
* download the file highlighted below (Win7 - after download, you may have to right click it and "unlock"the zip and dll)
* extract anywhere - RIGHT CLICK the INSTALL.cmd file and select "Run As Administrator"
* if all goes well .. you should see Sheet Creator under external tools
RevSheetCreator.zip (106.13 kb)
Thanks to Krista Manna and David Baldacchino for their feedback during the writing of the app.
- Manually insert multiple sheets and/or placeholders
- Import a text file or xls file with preset sheets (sample files included)
- Convert existing placeholder sheets to actual sheets (similar to ootb functionality)
Installation
