If we want to schedule a nested family we can do it however its coming in showing the family name and the type. We just want to see the type name. This is for Base Plates in Column Families. Any suggestions?
Scheduling a Nested Family with just the Type
Originally posted by msbeham View PostIf we want to schedule a nested family we can do it however its coming in showing the family name and the type. We just want to see the type name. This is for Base Plates in Column Families. Any suggestions?I'm retired, if you don't like it, go around!
Assuming that you are scheduling the type of the nested families in the same schedule as the parent families, then no - You´ll only get the famliy:type from the shared parameter that you´ve created to choose the nested family from within the parent.Klaus Munkholm
Make it Shared and check the "appears in schedule"? Or is this option not available for this Category?Martijn de Riet
Originally posted by msbeham View Postany fun workarounds to get it to just read the type?Klaus Munkholm
Originally posted by mdradvies View PostMake it Shared and check the "appears in schedule"? Or is this option not available for this Category?Klaus Munkholm
Originally posted by Dave Joneseven if you use the Type parameter rather than the Family and Type parameter?
Originally posted by MunkholmAssuming that you are scheduling the type of the nested families in the same schedule as the parent families, then no - You´ll only get the famliy:type from the shared parameter that you´ve created to choose the nested family from within the parent.
Below is an example of a casework schedule, of a project in which there is only 1 casework family without any type, named as "parent casework", which contains a nested/shared casework family named as "nested casework" with one type named as "Type 1". Notice the "Type" column in the schedule. When there is a type, it shows the name of the type. When there isn't, it shows the name of the family.
Solution: make sure the nested/shared family has types.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
I need to ping the community in regards to designing nested families using the family type parameter for shared nested families within...March 1, 2016, 04:14 PM -
Pretty sure I know the answer but, just in case, is it possible to control a shared/nested Family with a family type parameter deeper than the top level?...November 12, 2016, 03:13 AM
Hello all,
I get this when i try and load a family type catalog.
here is the txt file line.
here is the parameter...-
January 7, 2019, 10:46 PM -
I have only recently learnt to use the <Family Type> parameter to swap nested families in my AHUs and am loving it. I am using it to change the...
Channel: MEP - General
July 21, 2016, 09:18 AM -
I thought there was a way to do this. Within a Host Family, is there a way to globally associate all the Shared Parameters? That is: without having to...
May 27, 2016, 10:56 PM -
Monumetric Footer In-screen
